Check out my recent post in this section of the forum on taking the bottom down to bare metal before barrier/bottom coating it. It's based on a conversation with Interlux. Time between steps is quite important.
(Joe: where does the chlorine you noted come from)
BTW: I was down at the marina yesterday (Sunday) to wash and wax the hull. Instead, would up taping water line because yard mechanic came in on his day off to pull my boat into position. At close of business Friday, the soda blaster called to tell the marina his people would start my job first thing Monday morning. Of course, my boat was behind others. Five boats had to be unblocked, shifted, reblocked before the mechanic could jockey mine into the clear.
The mechanic (actually, the guy who will do the painting) had me lay down the regular 3M blue waterline tape. Over it, he gave me some 4" wide shrink wrap tape to go over the other, less aggressive stuff. That way, the shrink wrap tape which sticks almost like glue, will be easier to remove.
I also put aluminum from pie plates over the Capac, depth sounder and speed paddle.
I will be on hand Monday to watch the process. Should be quite interesting.
PS: yard neighbor pointed out to me that a pair of robins had built a nest on one of the flukes of my anchor that hangs right under the bow pulpit. Yep, there were three newly hatched babies in it and the parents were trying to come by to feed them while the boat was being moved. I hope they came back after we left this evening. Tomorrow, with the soda blasting, I don't think those unfortunate chicks will get fed. What a shame. And if I launch in about 10 days as expected, they will be over water with little chance of survival. Life sometimes is unfair!
