The other place to check is the back of the fuel gauge. If the wire leads are shorted there you will see a reading of full.
I am chasing the same gremlin. But my readings are too low.
I replaced my sender in the tank but the readings are still off.
I tried grounding the sender wire and it pegged the gauge as it should.
I am now going to try a jumper wire from the sender to the screw post on the back of the gauge to see if the readings change.
I bought the resistors that Doug suggested and will try that test as well.
Either the sender wire has a bad connection somewhere or the ground behind the gauge panel is faulty.
There is a terminal block in the wine cellar under the lower helm. The connections there might be corroded.
I will take pics and report back.
