2 Pages12>
electrolysis meter
boatinfree
#1 Posted : Saturday, August 16, 2008 4:10:06 AM(UTC)
I have been told that i should have a ideal .90 on my meter on my marinette 39 ft. aft cabin.
We have gone through all electrical including new power cords and best i can get on the meter is .60
We used a portable meter out side the boat and got the same reading on the docks.
We replace all the old anoids with the required and proper anoids.
my friend down the pier has a marinette and he only gets .60
Even out on the lake it reads .60
The boat is located in the fresh waters of the kentucky lake.
Is this a normal reading
Joseph Favier
#2 Posted : Saturday, August 16, 2008 8:01:16 AM(UTC)
On SI the ground wire (hooked to ships hull) was snipped off at the shore power receptacle. I decided to reconnect it to see what effect it would have on the Capac. Reading went from .92 to .63. The reading jumped back up when it was cut.
ps-found this in the 'sticky'...
marinettejoe wrote:
This happened in my experience when the air conditioner in a nearby boat would turn on. That boat was wired in such a way that the neutrals (white) were connected to its grounds (green) at the shipboard electrical panel when connected to shore power. Unless an isolation transformer is used this a no-no as it can cause AC currents to flow through water. Part of this boat's neutral current was passing through the ground wire (and possibly the water) all the way back to the marina's main breaker panel where the neutrals and grounds are supposed to be connected. This current causes a small AC potential difference between the ground (green) at the boat and the ground (green) at the main panel or transformer feeding the dock to develop. Unless there is a ground fault, there should be no current flowing in any ground wire and hence no potential difference. Prior to general acceptance of ABYC guidance, several boats were wired with the grounds (green) sharing the same shipboard panel bus as the neutrals (white). As soon as the boat described above made the change and separated the neutrals from the grounds, the problem went away. I have also seen several boats with neutrals connected to grounds that left the factory with neutrals separated from grounds. In these cases, owners or workman who were unfamiliar with the need to keep them separate joined them together.
#3 Posted : Saturday, August 16, 2008 10:46:51 AM(UTC)
The answer is....magnesium, magnesium, magnesium! Trust me on this (in fresh water only).
walt2007
#4 Posted : Saturday, August 16, 2008 11:43:08 PM(UTC)
walt2007
I too am in fresh water and have a consistant reading of .65 to .70. This is true when at the dock, connected to shore power or when out in a cove with no-one else around (and without generator). I've checked the prop shaft to hull voltage and see about .25 on the port engine and zero on the starboard engine. The new anodes we installed before re-launching this spring are burning up. I think I may have to replace them annually based on the amount of activity. We have started using a drop over the side guppy anode while at the dock. Should the meter readings change with the guppy connected?
DiverDennis:
Before your wiring was fixed, did you experience the same low readings whether connected to shore power or not? I would really like to get in the good range!!!!!
1988 Sedan Fly Bridge
Twin Crusader 270's
Home Port: Lake Lanier GA
#5 Posted : Sunday, August 17, 2008 2:05:07 AM(UTC)
..."Should the meter readings change with the guppy connected? "
Yes, an especially if it's a mag guppy. I've seen about 0.1 to 0.2 volts improvement with mine (not that I need it anymore).
Don't like that prop shaft reading. I suspect there's a metal-to-metal connection somewhere, possibly a coupling bolt that's touching where it shouldn't be.
PS: If I were you, I'd bolt on a nice block of magnesium and watch those readings go up.
#6 Posted : Sunday, August 17, 2008 2:07:42 AM(UTC)
If you have not done so already, calibrate the CAPAC with a digital multimeter.
Hook a meter in parallel with the leads feeding the CAPAC and read the voltage. Use the little plastic adjust screw on the face of the CAPAC to set the needle as close to the reading of the digital meter.
If the readings are still low you may have a wire that draws significant current too close the CAPAC wires. I know when I run the engine blowers the CAPAC takes a dive. I think the wires are so close to each other there is an induction issue, but not really sure about that.
Test the CAPAC with the shore cord unplugged, like you did out in the lake, and also test it with the battery switches turned off.
You may also want to test the CAPAC reading with all of the battery negative cables disconnected.
I've also found as the summer progresses and the Lake gets warmer the reading goes down.
Also be suspicious of your dock neighbors. I had a guy 2 docks down from me with a melted shore cord plug. It was dumping voltage on the ground, making my galvanic isolator buzz.
#7 Posted : Sunday, August 17, 2008 2:40:33 AM(UTC)
Karl,
It is possible that the meter ground is not going directly to the hull, but through the ground system of your boat. You could be seeing the voltage caused by the resistance in the ground return for the blowers.
#8 Posted : Sunday, August 17, 2008 9:05:15 AM(UTC)
dougrose wrote:
Karl,
That makes sense. I'll have to trace the wire.
tntinboat
#9 Posted : Friday, September 05, 2008 1:53:16 PM(UTC)
Rank: New Poster
I want to get in on the discussion about low readings on the meter. Mine has never read over .65 in fresh water on the TN River. I hope that the new anodes on the keel that I intend to install soon will help. My actual question is in reference to the magnesium guppie I bought from Marinette Yachts. When I hang it over the side and attach the ground wire clip to the hull I get no change in the meter not even a few 10ths. Am I doing something wrong?
#10 Posted : Saturday, September 06, 2008 1:04:26 AM(UTC)
Sounds like you have to work back. My boat is a in Lake Barkley and I also boat in KY lake.
After three years (three full summers) my readings have gone down a little.
.65-.72. I replaced anodes at last haul out and readings were up to .95 for the past 2 summers.
I have growth on bottom and am losing continuity between anodes and cathode so I added mag guppy this summer.
With guppy redings jumped up to 1.05 and are steady.
Now it sounds like you have either an isolation problem (since guppy is not changing readings) or your silver silver Chloride cathode has been damaged or painted over. also sometimes the single wire which is going to the cathode is disconnected broked or just damaged.
When I haul in a week for paint I will clean anodes and assuming they are still in good shape my hull readings should come up to normal without the guppy.
one test is take a jumper wire and have helper push activate your meter while you intentionaly ground the shaft to the hull or the engne the block. If the meter deflects downward they your shafts are properly isolated. If not they are not isolated and they will lower your readings and you will be unprotected.
You can check with an ohm meter also. Check for continuity between shaft coupler. There should not be continuity. There will be a very small amount o ohms but not enough to activiate a tone.
Also clean your anodes and see if the readingts change. Readings underway are not reliable and it can take several hours for readings to come up while at anchor.
Through process of elimination you should find the ground fault.
boatinfree
#11 Posted : Sunday, September 07, 2008 2:34:13 PM(UTC)
He Guys
It is Joseph Favier again with the 39 aft marinette in the kentucky lake
I am running out of ideas on the low readings .65 on the capac
Brain storming here
should the negative ground cables from the battery be connected to the stringers.
I noticed this on my boat. All the ground wires come to this connection on the stringer.At some point it is instructed to disconnect the negative from the battery to see if it has an effect on the capac
I have the same problem when i turned on the new blowers, that i installed, and the capac goes from .65 to about .40
There is something very wrong here
John Althouse is sending me some mag guppies.
but that does not take care of the problem on the lake anchored
that is why i thought about this negative cable attached to the stringers
I was thinking about removing the negative cable and other ground leads from the stringer. I know that the engine needs a ground to operate.
Give me some geed back on this boys
Joseph Favier
#12 Posted : Sunday, September 07, 2008 2:45:15 PM(UTC)
ALL ground wires?
Your 12 volt ground grounds to the stringers or the bulkheads.
110 volt NEVER grounds to the hull! Your shore power, gen, inverters must should run through a gavanic isolator or a isolation transformer. If DC current leaks through on your incomming 110 system it will cuase electrolysis.
Test your system with both your pos and neg cables off your batteries and disconnect your shore power.
#13 Posted : Monday, September 08, 2008 12:58:24 AM(UTC)
Are the new blowers 2 wire, or automotive type with only one wire which uses the hull for ground path?
Look care fully at the "stringer" is it insulated from the Hull?
I would think that battery "negative" should go direct to the engine frame which should be mounted on rubber mounts and therefore insulated from the hull.
#14 Posted : Monday, September 08, 2008 4:18:34 AM(UTC)
Roger,
Battery negative must go to the engine block (best to a stud on the starter) so that the starter will work. The engine block, in turn, should be connected to the hull but a large wire is not needed. This is how most cars and trucks are wired.
If you have a good ground block (mine is 6 3/8" bronze studs welded to a piece of 1/2" copper) then you can run the battery negative to one of the studs, and another heavy wire to the block. Fastjeff also does it this way. This setup is easier to work on at the cost of putting the starting current through a couple of extra connections.
Either way, the engine block is at the same potential as the hull. The block and hull are insulated from the shaft and prop by a nonconductive connection between shaft and transmission, and by the rubber and fiber bearing between the strut and shaft.
My 32' had things grounded to the hull all over the boat -- the trim tab pump, the head, and so on. I recommend replacing these grounds with wires of the same size as the power feed wires, leading back to the ground plate.
#15 Posted : Monday, September 08, 2008 6:26:51 AM(UTC)
I had battery neg. grounded to the hull from the factory. I also had to put a new bottom on, due to corrosion.
I put an isolated neg. bus in for the neg wires and isolated the engines from the hull. Just pretend you have a plastic boat and run two wires to everything and you're safe. Did have trouble isolating the wiper motor from the hull, but it can be done. Then check everything with an ohm meter to be sure
#16 Posted : Monday, September 08, 2008 7:13:33 AM(UTC)
Marinettes came from the factory with the negativ12 volt DC grounded to the hull. THis does NOT include the 120 volts AC ground, unless it goes through an isolation transformer first.
I doubt if you could isolate every 12 volt DC item from the hull.
karrakmc
#17 Posted : Monday, September 08, 2008 7:41:37 AM(UTC)
FastJeff, why do you advocate using magnesium when john sells aluminum? Not sure what to buy. Thanks, Mike
#18 Posted : Monday, September 08, 2008 3:03:56 PM(UTC)
Mike:
I have BOTH. Without the mag, in fresh water, I struggled to get above 0.70 volts. No problem now.
boatinfree
#19 Posted : Monday, September 08, 2008 4:18:48 PM(UTC)
Hey Guys
Thanks for the help
The blowers are a 2 wire i never use the hull for a ground on 12v a/c ground to hull is a no no a big no no
anyway so i will disconnect both positive and negative from the batteried and disconnect the shore power and see what i get
It will be some time before i get down to the boat to do this
if the capac gives me a higher reading then i will start to investigate the ground to hull from the battery
if it does not chage then i will take a mag guppie and see if it changes the reading
if it does i have room on the trim tab to add a piece of mag on it and see what the readings are and adjust the amount of mag i put on the trim tabs to get it to .95
I assure you that i will let you guys know if this will work by putting some mag on the trim tabs
this .65 reading can drive you insane so when i see what my results are i will inform you all on here
again thanks for your imput
will be in touch
Joseph Favier
#20 Posted : Tuesday, September 09, 2008 1:03:37 AM(UTC)
12V DC hull grounding is in accordance with acceptable marine practice. It is NOT the source of your problem.
Now grounding of disimular metals (SS shafts, props etc. will deflected you readings down. GALVANIC corrosion occurs when two metals are submerged in water. (Not pure distilled water is a poor conductor and there would be little or no raction between metals. ex: bronze/SS/Alluminum. Now is salt, or fresh lake water with sediment etc. conductivity increases and so the flow of electrons from less noble to the more noble metal.
It is easy to confuse electrolosis with galvanic. Stray DC voltage will cuase damage much more quickly than galvanic.
Stray AC while EXTREMELY DANGEROUS has minimum effect on corrosion.
Your CAPAC actually is reading Negative voltage. and ideal reading of .95 is actually -.95 of a volt.
If you have water in your bilge pay attention to what is in the bilge water. A missing tool in a partially flooded bilge will have an effect on your readings and can also cause a hot spot for corrosion.
2 Pages12>
This page was generated in 0.475 seconds.
