What is above the rub rail? Options · View
minnesota dan
Posted: Thursday, October 02, 2008 6:28:16 PM
Rank: New Poster
I apologize in advance for the vague subject line. As I read the following I realize it may be difficult to follow, please feel free to ask for clarification, no offense will be taken.
I need to know if the bump in the deck just above the rubrail on a 41 Marinette is solid or not. This bump up is to assist in the channeling of water on the deck to the rear of the boat. The problem I am having is that the water does not fully drain from this channel and I have about 6 inches of water about 1/8" deep that accumulates on the boat on a daily basis. It is on the NE side of the boat and the sun does not get there at all to dry it out. The water has accumulated at the extreme rear of the boat and has lifted up Awlgrip paint. Awlgrip rep claims this is an issue because Alwgrip top side paint is not designed to be under water. I need to get this water to drain out fully.
I was planning to cut a small kerf in this bump to allow the water to fully drain out. I need to know if any one knows if this bump is solid or not. If I cut the kerf and bump is not solid then I will need to fix the cut and then go to plan 2.
Plan 2 was to put a small drain hole in the deck and route it to the hull to drain over board. I am not sure of the access to this area from the inside. I have already removed the failed Alwgrip paint and need to repaint this area. I was thinking about a 1/8 inch drain hole.
I would also appreciate any information any may have on this and additionally if anyone has addressed this issue in some other manner.
Thanks in advance
Dan
Posted: Thursday, October 02, 2008 7:13:06 PM
Minn.Dan,
I’m not positive but I’d say it would be a solid piece of 1/2 round stock Think ahh it just came to me take the
smallest drill U own say a 1/16" & drill thru depth of the round where U plan on cutting the kerf but not the deck U’ll soon find out if it’s hollow or not. Pray If & when U do this chore how about letting the rest of the forum know the out come Brick wall so we don't have to do thisBrick wall
BigBigMs Live On Applause
rrbrown
Posted: Thursday, October 02, 2008 10:15:01 PM
Rank: New Poster
Dan,
We have the same problem on our 39. The bump you speak of is not solid, it is a extrusion and you would probably cut through it before you could get all of the water to drain. There is a cross section of the hull in one of the brochures on this site that shows it. I was thinking of raising the area by fairing it forward far enough to allow the water to run over the top of the bump.
I can email you the picture if you can't find it.
Rob
bpboater
Posted: Friday, October 03, 2008 7:13:50 AM
For just this small area, consider using a different paint that can be kept underwater - epoxy bottom paints are designed for this.
clarko
Posted: Saturday, October 04, 2008 5:37:59 PM
click on "search" in the logged in as: line and then type in "old Marinette brochures". There is a whole pot full of brochures that I and several others put on there. Scroll down, waaay down and you will come to pictures of construction of the hull. It shows the extrusions. The bump or gun'l is hollow and the deck slides into it on one side and the hull slides into it on the other. If you drill or cut the bump it will drain directly into the hull. It is always interesting to look at all the brochures and see the different layouts.
Goldpoint
Posted: Monday, November 24, 2008 4:08:43 PM
I almost didn't find this post this evening....
I was rooting around on my boat a bit earlier and found a couple of cross-sections of hull construction laying in the bilge area under the forward bunk. I guess these were used as sales tools back in the day to provide some detail on construction. Just a guess. I took a couple of quick photos. Will try to get some better ones later. This cross section of the extrusion with deck and side pieces welded in should answer the question concerning what is under the 'bump' on the deck. The other cross-section appears to be the keel.
John B.
Goldpoint attached the following image(s):
1979 28' Flybridge Sedan - Single M360
Docked - Chickamauga Marina, Chattanooga, TN
Posted: Monday, November 24, 2008 5:51:40 PM
John,
Nice post! I've seen that in drawings but it's good to see the actual material.
Posted: Tuesday, November 25, 2008 5:34:14 AM
Awesome photos!
When I sanded the deck to raw aluminum it looked to me that my BigM had a red rubber between the deck and the upper part of the extrusions U. This coud have just been a thick primer coat but the only place I found it was near the rub rail. Either way it would seem that welding eiher side would have cooked either material away.
"LIFE is what happens to you, while your making other plans."
Pfhlaw
Posted: Tuesday, November 25, 2008 7:41:55 AM
Wow. No wonder these boats are so solid. These interlocking Marinette extrusions are amazing. They tie the two halves of the hull and the deck and gunwales together and provide a continuous interlocked and welded connection, not just where a screw would be like on a typical fiberglass seam.
Posted: Tuesday, November 25, 2008 12:40:47 PM
Groups: Member , Other Mods
Location: DeWitt, MI, but spend most of my time at work(LDT)
Goldpoint wrote:
...will try to get some better ones later. John B.
Thanks for taking the time to post the pictures. They are like Xrays.
1975 28' Express, Single Chrysler M360 ('87), Raymarine E120 MFD, HD digital sonar, GPS,
4KW radome, S1G AST autopilot, SIRIUS satellite weather, Floscan 9000, 25HP Mercury kicker,
24 volt stern thruster, Interlux Brightside paint ('06-'08) Trilux 33 on bottom,
Big Jon electric downriggers, Traxtech swivel mounts, Bert's track and ratchet holders.
Goldpoint
Posted: Wednesday, November 26, 2008 2:27:33 AM
A few more photos of those two extrusions that are a bit better. Looks like the smaller cross-section is the extrusion used to join the bottom to the side. Note the difference in metal thickness of the plates.
Goldpoint
Posted: Wednesday, November 26, 2008 8:26:14 AM
Now, that photo I can understand. The other ones are still confusing.
Thanks for posting!
"Don't follow me--I'm lost!" (From the Simpsons)
Posted: Wednesday, November 26, 2008 2:55:57 PM
Good job on the photos
Posted: Wednesday, November 26, 2008 3:09:27 PM
Yes...great!
Norm dosen't even need his quad-focal glasses.
My topside deck was not welded though. I've got that red rubber stuff on top and too much black crap underneath to tell if it was welded there. Maybe it's just JB Welded together...
Guest2
Main Forum RSS : RSS
This page was generated in 0.444 seconds.
