old32 wrote:...also any one know what the two oil pressure switchs are for???tim
In this photo of our M360, you see the pressure sender unit (top), and 2 pressure switches. The one on the left (single wire) goes to the "low oil press" alarm and the one on the right is wired in series with the alternator field coil.
Found these in a search:
http://www.marinetteboat.com/ChryslerEngine.pdf
TYPICAL ENGINE WIRING HARNESS COLORS
PURPLE--------- IGNITION
LIGHT BLUE---- OIL PRESSURE
YELLOW/RED---STARTER
GREY------------(–) COIL (FOR TACH)
TAN-------------WATER TEMPERATURE
BLACK----------GROUND
RED-------------BATTERY
PINK------------AUX (FUEL – BUZZER – ETC)
Hope this helps.
Dennis
Specs:
