Shorepower, transfer switch & genny
Postby shade2u2 » Tue Aug 14, 2018 1:34 pm
On our 1986 39 Sedan, there was a stern shorepower plug in set added recently by the PO. So it has dual 30A plugin's up front at the bow seat and dual 30A plugin's in the rear cockpit. They are connected at a "Blue Seas" brand switch that has bow - off - stern options. AC power is also tied in with the newer Kohler 7.3 generator. The genny works when the switch is set to the bow position. I assume there is some sort of transfer switch tied in with the genny and AC panel somewhere.
ANYHOW... I have had low readings (.63 to .70) on my CAPAC since going in the water at our dock. I had not been to concerned yet since all 110V items on the boat worked without any breaker issues on the boat or at the shorepower pole. Polarity checks out on all outlets. I started to troubleshoot the low readings a little over this past weekend by starting with the shorepower input. I found that the low reading exist when either of the two stern plugins are connected to a cable or a cable is connected to the top bow plugin. Oddly enough, the cables do not have to be turned on at the pole in order to get the low capac readings - just plugged in... When only using the lower bow 30A plugin, my capac reads .9+. For now that is all that is plugged until I can figure out more. This 30A side powers the solon A/C, refrigerator, galley and starboard outlets so we can function short term.
That is about as much as I have learned at this point. As you can probably tell, I am not an marine electrical expert. I know that the "Blue Seas" switch is the proper one because I spoke with the Blue Seas technician before closing on the boat. I am concerned that he PO combined neutral inputs on the boat with a busBar because he installed the busbar for this switch installation. This is where I plan to start this weekend. I need to open the panels up and see what I can learn.
Well, any words of wisdom from you smart guys here? Where would you start?
Thank you in advance,
This is the switch:
https://www.iboats.com/shop/blue-sea-sy ... 3UQAvD_BwE
w/single 360 1.5:1 drive
Re: Shorepower, transfer switch & genny
Postby Joe » Tue Aug 14, 2018 5:20 pm
Check/ disconnect your water heater. I had a heater element split. It still worked, butt it was back feeding.
barefoot99
Postby barefoot99 » Wed Aug 15, 2018 8:51 pm
Make sure common and ground are separate through all the switches - gen hookups sometimes share them. Second the water heater check
S UP !
1982 32 Sedan FB
2003 hrs
Norris Lake
Speedwell,TN.
Postby shade2u2 » Thu Aug 16, 2018 8:54 am
My readings and electric leak issue actually occur without any breakers or systems drawing on the panel. Actually the low readings occur with all main breakers turned off. Only the shorepower cable is connected. The water heater is only a year or 2 old but will double check it. I believe that the problem is somewhere in the shorepower (bow/stern) switch, galvonic isolator, isolator genny switch, and/or panel itself. I am concerned that neutral is combined on a busbar. I'm trying to learn enough to begin trouble shooting.
Postby jralbert » Thu Aug 16, 2018 11:23 am
I've heard that sometimes these problems originate at another boat
Postby shade2u2 » Thu Aug 16, 2018 11:49 am
jralbert wrote:I've heard that sometimes these problems originate at another boat
Thank you for the idea.
I thought about that, but I think that I eliminated that by narrowing it down to three of my shorepower plugins. One specific shorepower plugin gets me a reading 0.90 plus while the other 3 plugins send the capac meter to about 0.65. There is a Marinette houseboat in front of me that gets good readings on their capac.
Postby Joe » Thu Aug 16, 2018 3:33 pm
With the breakers off. Disconnect the "white" wires one at a time. Disconnect the water heater completely. Every wire going to it.
