Exhaust Manifold Options?
Apparently i didn't get all the water out of on of my manifolds when pulling the engine out for rebuild over winter. Nothing like adding insult to injury. Anyone know where to get a used or reasonably priced exhaust manifold for a 1987 318?
Re: Exhaust Manifold Options?
try MetalHead (member)
I should have a few good used ones. How many do you need? What style do you have?
That would be great EW. I only need one at the moment. Attached is a pic of what I have. Its from the reverse rotation engine port side.
Unfortunately you have the less common manifold that was only used in the last few years of Chrysler Marine production. I do not have any of those manifolds but I believe they are available new at just under $500 each.
That may be able to be welded. I had one repaired at this place in Cleveland:
Guarantee Auto Weld Co Inc
216-431-1214
216-431-1214
Located: Edgewater Yacht Club
Lake Erie
Lake Erie
That's the same style I put in my 74 318 when I converted to FWC. That's a Barr Marine CM-1-4417063 Manifold available here for $326.99 new
https://www.marineengineparts.com/barr- ... 3-manifold
