Post by bill »
My last write up on this 4 year on going problem. Finally put this post to bed. :!:
Last fall I replaced the wire going from the ignition switch to the ballast resistor with a new 14 gauge tinned marine grade wire. I followed the orginal wireing harnes and tyraped and taped the new wire to the existing harness with no splices. Took it out for a run and everything seemed ok. Topped off the fuel tanks and pulled boat and winterized it for the winter. Our club has its own fuel dock with 90 octane and no ethanol added too the fuel.
This spring I replaced spark plug wires and plugs. I used wires for a 1975 Chrysler 360 Truck engine and Autolite plugs. These are the wires that go from the distributor to the plugs along side the valve covers. Makes for a neater looking engine. I did notice the new wires were a lot shorter than the old wires that went under the manifolds almost laying in the bilge. :shock: Posible the old longer wires were causing to much resistance. :o I did notice that the old plugs looked like the were starting to foul. :?
This spring after launching both engines started up and ran really well. That is until the port engine stalled and would not restart. After troubleshooting I found the port fuel tank had somehow collect water over the winter. :?: This boat has two 125 gallon fuel tanks. :roll: So after removing two gallons of water from this tank and pulling the top off the carb to remove the water from the bowls. Reassemble the carb and restarted the engine I took it out for a cruise bow up I remove about an additional pint of water from that port tank.
The real test was the past weekends trip to Put in Bay OH. 70 miles round trip. We cruised at 2800 rpms and 19 mph and average 1 gallon a mile. The engines did not sputter or bog down. They purred. :D
Good night Sweet dreams. :D
Glad to hear that. I fought a starting issue on Mr. Port for 8 years and never cured it, so I appreciate your achievement.
railrunner04
Post by railrunner04 »
:lol: Forgot to mention that's holy water I poured in the tank while you were in Florida seems like it worked hope you dont mind :!:
Moby Rick
FYC grosse ile mich
32ft F/B express
1971
T/318 Chrysler marine
Post by bill »
My final entry for this post.
I found this gentleman.
My problems were solved.
https:carburetorsandmore.com
Take a look at his website.
Look at his YouTube videos
My problem was the mechanical fuel pumps were over riding the carburetor float needle valves and flooding the engine out. :shock:
I installed Holley 12-804 carburetor fuel low pressure regulators set at 3 psi on both engines and my problem went away. :D
Rlfa83
Post by Rlfa83 »
bill wrote:BigM
Bill,
My argument would be. If indeed the pump was overriding the floats. Wouldn't this have been an issue since the beginning of the boat (per say)???
It just seems that it's more of an issue with older set ups that have seen limited use....
'85 Marinette 32' Sedan
Twin Chrysler 360's
Catawba Island. OH
Be careful running fuel pressure that low, for you might lean out the motor if, for some reason, you had to 'step on it' hard for a few minutes.
tundrarules
Post by tundrarules »
Fastjeff wrote:Glad to hear that. I fought a starting issue on Mr. Port for 8 years and never cured it, so I appreciate your achievement.
Funny you say this Jeff, I have the same issue with my port engine. Have done all the basics and still takes a long time to wake that engine up after it hasn’t been started for a few days. Likes to backfire a few times and takes a long time to crank. :roll: Guess If Jeff can’t break the mystery, how could I :D
1985 29 Sedan
Edelbrock 1409 carbs
Mallory distributors
780 hrs/eng
TN River, MM 213.8
:mrgreen:
