Water in my front compartment
MyWay
Postby MyWay » Wed Dec 23, 2015 6:32 pm
Can't find were water is coming from . Boat is under cover . Very little rain hits it . Any ideas?
MyWay ( grandpa bought it and named it
Just trying to get it to a 4th generation)
32 SFB Holland,MI
TWIN 318's
Currently in Aurora Indiana
Lighthouse Point Yacht Club
Tranquilo
Re: Water in my front compartment
Postby Tranquilo » Wed Dec 23, 2015 9:33 pm
You mean the vberth bed?
Miami FL & Catawba OH
Postby jralbert » Wed Dec 23, 2015 10:26 pm
Without knowing how much and what parts are covered, this is a total guess here: windshield, deck fittings, hatch
Postby Fastjeff » Thu Dec 24, 2015 7:16 am
In re-painting my forward deck, I didn't reseal the port light fixture properly and water came in--you wouldn't believe how much! (Only time I ever heard that forward bilge pump run.) I'd start looking there.
MyWay
Postby MyWay » Thu Dec 24, 2015 7:52 am
The nav lights?
That part of the boat gets a bit of rain from time to time.
32 SFB Holland,MI
TWIN 318's
Maestro
Postby Maestro » Thu Dec 24, 2015 10:31 am
My 28' leaks water in from the front cleats and I'm also suspecting the railing stanchions where they bolt into the deck.
Someday I need to take all the deck fittings off, repaint, and seal everything up when I re-install.
Maestro
1970 28' Express
Single Chrysler 440
Mississippi River
DougDoty
Postby DougDoty » Tue Apr 18, 2017 8:58 pm
This is an old question but after years of curiosity and looking I am certain that air conditioned Marinette hulls condensate on the hull sides and run down into the bilge in the summer. My boat never gets enough water to pump it out but the amount is always relative to how much and how long the AC has been running. It is not possible to have a dry bilge forward if you run Air Conditioning and I am no longer concerned by the small amount that collects since I understand the source.
ddependo
Postby ddependo » Wed Apr 19, 2017 7:43 am
The lowest part of my express is in the bow. Water that come from the shaft seals ends up there on mime.
DougDoty
Postby DougDoty » Thu Apr 20, 2017 12:43 pm
My front and rear compartments are separated by the firewall in the engine area in my boat so I do not see any flow back and forth.
Postby shade2u2 » Thu Apr 20, 2017 1:37 pm
DougDoty wrote:My front and rear compartments are separated by the firewall in the engine area in my boat so I do not see any flow back and forth.
Same here...
Wasn't the hull designed changed around 1982 or so?
