Before I crank and sitting for years
Re: Before I crank and sitting for years
Pull them out and put twin four stroke outboard on it
After massive strengthening of the transom!
I actually have another 32' Express that has been gutted out. No engines or interior. It would be great for putting outboards behind it. I found this and thought it would be cool to make that Hull into a center console boat with twin outboard engines. Just need to cut the roof off and continue the cockpit floor all the way to the front and yes strengthen the transom.
http://www.thehulltruth.com/boating-out ... ild.html#b
1968 32' Fisherman
beginning restoration fall of 2014
Lake Sidney Lanier
Lake Sidney Lanier
I'd be interested in the hull with the trailer but not separate.
You really don't need stands to hold the hull. I used railroad tie sections for mine the first time. It's really easy to get the boat off the trailer. I did it with a 20 ton jack and blocks. I've since bought boat stands and you're welcome to the railroad ties.
I'll send you my contact info by PM. Happy to help you get it done.
BTW - I saw this post on Craiglist for 2 complete 318s in TN. http://tricities.craigslist.org/boa/4624712799.html
Eric
Eric
Eric Spies
1989 32 SDFB
Lake Lanier, GA
1989 32 SDFB
Lake Lanier, GA
whats the easiest way to access the outside sides of the engines for the spark plugs? Do people take the exhaust manifolds off?
1968 32' Fisherman
Lake Sidney Lanier
Lake Sidney Lanier
Put a blanket over the motor and lay on top. Do NOT go messing with that manifold!
