HIN on a Marinette 32
weybug
Post by weybug »
Hello,
About to register our new to us Marinette 32 for the first time. Arkansas now requires a photo of the HIN. Can not find HIN.
Maybe it is under 40 years of paint on transom? Just paid to repaint boat. Do not want to start ripping paint off.
Where on hull should an HIN be on a 1978 Marinette 32? Does it stamp deep enough that it might be visible from inside of hull?
ddependo
Re: HIN on a Marinette 32
Post by ddependo »
Number is stamped into the transom starboard top corner. you won't see it from the inside.
weybug
Post by weybug »
Thanks.
Guess ours is under 40yrs of paint.
weybug
Post by weybug »
I may have to go at that with a sander to satisfy the state.
Anyone have a photo of exactly where it is? Would appreciate it if that could be shared.
Tuggle
Post by Tuggle »
ddependo is right, discovered mine while painting over the weekend.
weybug wrote:Anyone have a photo of exactly where it is? Would appreciate it if that could be shared.
I know you can't read the numbers but I think the annotated blowup is self-explanatory
MetalHead
Post by MetalHead »
Should be in the rub rail not on the hull.
I would use paint stripper if the rail is painted .
Big BigM 's Rule !!!
weybug
Post by weybug »
Thanks. I was not quite looking in the right place.
Yes, photo above meant to show rub rail location. It appears it may be a strip of metal screwed to the rail (but my recollection is faint and the numbers could have been stamped into the rail itself.)
Post by bill »
The number could also be on a plaque inside the hanging closet door. 8-)
