WANTED Prop LH 16 x 15 x 1, Neutral Safety Switch Cover
Leviathon
Postby Leviathon » Sun Nov 12, 2017 8:45 am
Looking for a couple things. Need the cover plate for a velvet drive that houses a Neutral safety switch - just need the cover plate. Also, need a prop that measures 16 x 15 x 1 - LEFT HAND ROT.
Steve and Mary Levi
1973 32' Marinette Fisherman
SBC Crusaders
El Ohssa
St. Joseph, Michigan
Re: WANTED Prop LH 16 x 15 x 1, Neutral Safety Switch Cover
Postby EWRice » Sun Nov 12, 2017 8:18 pm
Do you need the blockoff plate or the mounting plate for the switch.
CaptainOpus
Postby CaptainOpus » Sun Nov 12, 2017 11:02 pm
There is one in Cleveland Craigslist
Leviathon
Postby Leviathon » Mon Nov 13, 2017 5:42 am
Thanks Captain Opus. Mounting plate is what is needed on the tranny for the switch. I have switch and thingy that goes under it.
Steve and Mary Levi
SBC Crusaders
El Ohssa
Leviathon
Postby Leviathon » Mon Nov 13, 2017 6:10 am
Shoot - 1 1/4 on the bore - could sleeve it but would rather not.
Steve and Mary Levi
SBC Crusaders
El Ohssa
Postby EWRice » Mon Nov 13, 2017 11:13 am
I have the mounting plate you need. Let me check my prop wall and see if i have what you need. It would need a tune up if i have one.
MetalHead
Postby MetalHead » Mon Nov 13, 2017 12:36 pm
Your boat have 1 inch shafts? Better check that one to make sure with twin 360's .
Big BigM 's Rule !!!
Postby EWRice » Wed Nov 15, 2017 7:58 pm
I checked my props and every one is RH. No 16s either.
