Ceramic starter item
GregM
Post by GregM »
Can someone tell me what this is. It crumbled when I tried to remove it. I am not sure what to ask for at the local part store or if it is marine specific? Its for a 318 Chrysler motor I am rebuilding and is part of the starter circuit. Any advise on where to get a replacement would also be helpful?
Re: Ceramic starter item
Post by EWRice »
That is your ignition ballast resistor. You must have electronic ignition. Sierra p/n 18-5451
I think the automotive ones are the same.
GregM
Post by GregM »
Thank you man! I can't afford any more marine costs! Your a life savor!
Post by javalin390 »
Hold on there !! You MUST use the marine specific ballast. The automotive version is not sealed and thus will cause an engine room fire. I think NAPA carries both auto and boat ballasts for close to the same price, but you MUST use the marine version.
GregM
Post by GregM »
Stick with marine! Got it, thank you for pointing that out! No fire hazard is worth saving a few bucks.
hightension
Post by hightension »
Amazon carries them also. Just order 2 of them
Rodney Hack
Louisville,Ky
1975 32' sedan flybridgehttp://www.marinetteboat.com/forum/ucp.php?i=u ... =signature#
Post by bill »
Definitely carry a spare and make sure it is a Marine ballast resistor. The back will be filled with ceramic or epoxy. 8-) There is no way of knowing when it will burn out. Usually at the worst possible time. :roll:
Welcome to the world of Marinette.. :D
ps When you get a chance please add a signature to your posts.:)
