Raw water pump replacement.
Posted: Tue Feb 14, 2023 2:59 pm
by wschneid
I have an 86 32' sedan flybridge. I am trying to remove the raw water pump from the starboard engine. I want to change the impeller. It is more difficult than I thought. Does anyone have any ideas or instructions to help.
Bill Schneider
Re: Raw water pump replacement.
Posted: Tue Feb 14, 2023 8:33 pm
by barefoot99
Loosen the belt, remove the whole Sherwood pump assembly. Replace the impeller while off the motor. Install the assembly back on the motor. Line up
and start the upper and lower bolts before you tighten any of them.
Replacing the impeller in place is tougher and takes longer. Remember your direction of spin. I always mark in and out before I pull the assembly.
I also pull the upper hose of the intake for better access. Put the lower input hose on the pump, before you attach it to the engine.
Posted: Wed Feb 15, 2023 6:47 am
Good advice. Be sure you draw a diagram of the pump's connections and orientation BEFORE removing it or you' could get in all kinds of trouble. (Ahem!)
Posted: Wed Feb 15, 2023 7:30 am
by TinLizzy
Both have good advice. It also helps to take a sharpie and mark "top" on top of the pump before removal. It saves a lot of headaches down the road.
Posted: Wed Feb 15, 2023 7:36 am
by wschneid
On removal, is it necessary to remove the attachment bracket? Should I remove the hoses before trying to losen the 9/16 bolts?
Bill schneider
BTW. Does anyone have a part number to the raw water pump needed?
Posted: Wed Feb 15, 2023 2:48 pm
by TinLizzy
If my memory is correct, the pump will unbolt from the mounting bracket. Doesn't matter when you remove hoses, before or after, whichever is easier. I believe the part number was a 10615K, sherwood impeller, but I could be wrong on that, and everything else.
Posted: Wed Feb 15, 2023 2:54 pm
by wschneid
I've gotten the raw water pump off and removed the old impeller. There weren't any fins missing. I really believe my problem was a loose belt, which eventualy broke. I have a spare impeller, so I am replacing the old one. Some things I have read state that the new impeller should be lubricated before using. Any suggestions on what type of lubricant to use?
Bill Schneider
Posted: Wed Feb 15, 2023 3:36 pm
-congrats - pls share with the group what method you used to remove/thnx
Posted: Wed Feb 15, 2023 5:07 pm
by GB49
I use silicone grease on all rubber parts, gaskets, o-rings etc. Helps lube and should not breakdown the rubber. I figure any grease on the impellers will be blown off in short order anyhow. I only use it for ease of installation and initial dry startup.
-Karl
Posted: Wed Feb 15, 2023 5:43 pm
by Busia
I use dish soap
