Replacing Breaker in 120 Volt Panel!!!!
Jeepmanking
Post by Jeepmanking »
I made a YouTube video of me replacing breaker in the 120 volt panel with aftermarket marine/RV breaker. Hope this helps someone with their Marinette.
1987 Marinette 32 FB
#Fitforakingboatadventures
https://youtu.be/BYHZ0mr5BRU
Like and Subscribe to my YouTube channel many Marinette videos coming!!
Aaron King
Aaron King
Vessel Name- Fit For A King
1987 Marinette 32 FB Twin 318’s 525 Hours
Westerbeke 8.5 KW generator 674 hours
Metropolis,IL
barefoot99
Re: Replacing Breaker in 120 Volt Panel!!!!
Post by barefoot99 »
Why didn't you use an original style breaker?
Airpax breakers seem to work well.
SUP !
1982 32 Sedan FB
2269 hrs
360's-Edelbrocks, DUI
Norris Lake
Speedwell,TN.
While you are in there check for hardened/slightly melted spade connectors. I have replaced several over the years that got a little warm for a bit too long. Generally the water heater, AC, refer etc.
Seems like electrical was not a factory specialty back in the 70s/80s.
GB49 wrote: Sun Feb 19, 2023 9:41 pmSeems like electrical was not a factory specialty back in the 70s/80s.
Electrical shortcomings long have been documented. A flaw in otherwise outstanding boat. One area wired dangerously was/is the ungrounded circuit feeding the valance lighting on the sides of the cabin.
Jeepmanking
If you look closer during the video you will see lower on the panel the same style of breakers that I installed. Sometime in the last 35 years some breakers were replaced to this bolt in style. I am making at least one side of panel look the same, a little OCD, I guess. Lol.
Aaron King
Metropolis,IL
