Changing Packing Gland - How big of a job is this?
Tranquilo
Post by Tranquilo »
Gentlemen, its been a long time, I hope you all are well.
I'm getting ready to do my annual maintenance (3 years too late :) and have a question about changing out the packing gland with the goretex stuff.
1. is it a big job to do it?
2. do I have to pull the propeller shaft to do it?
3. if I pull the shaft, should I change the bearings? (I'm assuming the horrible chatter I hear when going up and down swells is a bad bearing... IDK)
4. is it worth doing if all I am dealing with is a little dripping in my bilge and a little grinding noise on the occasional big wake or high seas (lake erie) ?
Thank you all for the input - good and bad lol. If any of you are at Brand's Marina in Port Clinton, stop by and say hi. You can't miss the boat :)
D
Re: Changing Packing Gland - How big of a job is this?
If I were King: The grinding noise could be coming from multiple sources when you hit the short hard chop on Lake Erie. Push and pull on the shaft at the strut and if there's excessive (you're the judge) play, replace the bearing. Turn the prop - if it's hard to turn by hand, replace the bearing.
I once changed the gland myself following a boating mag article (long lost to history, but there are prob very good YouTube videos available today). Def go with Goretex per its reputation for longevity and effectiveness. Somewhere I read (Jeff, help me here) that G'tex requires one more or less turn.
If I could change it, any other idiot could do that and judging from your videos, that isn't you.
A little dripping in bilge is normal.
I am not King.
Tranquilo
Post by Tranquilo »
OK, followed your advice and everything was fine. A guy at the marina wiggled the shaft and said the bearing was fine, so I'll put it till next year.
Now for the corrosion issue (eek)
Tranquilo wrote: Sat May 20, 2023 7:05 pmNow for the corrosion issue (eek)
Look for exposed, shorting wires. Correct number of zincs making good contact and securely fastened
